Question Non-responsive Blue Eagle
9 years 4 months ago #187488 by Chistakus18
I want to turn my Bule Eagle Template (version 5) into a non-responsive forum, as it is in the PC view.
How can I achieve that?
I guess I have to modify the kunena.css and remove the @media part...
Does anyone know if there is a guide/documentation/something similar to make this change?
Thanks is advance.
9 years 4 months ago #187491 by rich
Replied by rich on topic Non-responsive Blue Eagle
Questions about blue eagle only in this specified category " Blue Eagle5 " please. If you bought the template, you should have automatically access. If you have no access send a email to jelle@*kunena.org (without star) so that he can check it. Then he will add you manually.
