Question All areas for comments are too short or covered with another box
8 years 10 months ago #186644 by lastevns
I have a new installation of Kunena and I have my first post and my first comments.
I find that the original area for posting is too short to show the tops of what is being typed and the area for responses is covered by a box.
Please see the attached screen capture.
Is there any way to fix this? I need a solution as soon as possible.
Thanks!
Laurie
8 years 10 months ago #186649 by rich
Please try in backend "Kunena -> Templates -> Crypsis -> Basic Settings -> Load Bootstrap css = Yes" or try the template Crypsisb3
8 years 10 months ago - 8 years 10 months ago #186655 by lastevns
@rich,
Thanks for the prompt response.
I tried both of the fixes you mentioned.
I first tried changing the default template to Crypsis and turning on bootstrap for the template. Everything looked great EXCEPT for one issue. When I hit reply to a message, the input box holding the TITLE of the the original post blocks out most of the title.
Then I tried changing the default template to Crypsisb3. It looks AWFUL.
So I cannot use that:
I can accept that there will always be these bad input boxes, if I have to. But is there a better option? Would buying the 10 pound template fix this issue or would I have the problem there as well?
Laurie
rich wrote: Please try in backend "Kunena -> Templates -> Crypsis -> Basic Settings -> Load Bootstrap css = Yes" or try the template Crypsisb3
Last edit: 8 years 10 months ago by lastevns.
8 years 10 months ago #186658 by rich
We would need a account as registered user, otherwise we cannot see this issue.
8 years 10 months ago #186660 by lastevns
Well, I registered for the forums. What else should I do?
Laurie
8 years 10 months ago #186661 by rich
When I the problem not see I can't help you. A image is not helpfull. Can you create a account for me? You can use the confidential tags (padlock symbol), then only you and we moderators can see it, or send the access data to rich@*kunena.org (address without star).
Time to create page: 0.274 seconds
