Question Will Kunena work with JomSocial 4.3.4?
9 years 3 months ago - 9 years 3 months ago #186560 by lastevns
I have a new JomSocial member site and I'm finding that members are less active than I'd like in the groups because they find them confusing. I would like to add some forums to my members' site. Will Kunena work for this purpose? And, if so, is there a special version of Kunena for JomSocial?
Thanks!
Laurie
Last edit: 9 years 3 months ago by lastevns.
9 years 3 months ago #186568 by rich
Kunena works with JomSocial. You don't need a special Kunena version.
9 years 3 months ago #186570 by lastevns
@rich,
Thanks for the response.
I have installed and configured Kunena and enabled the JomSocial plugin. I am now looking for a template.
After getting a template working, my next step is to find out if there is a way to have anything that is posted in my JomSocial groups automatically be reflected in the forums (and vice versa). I have read there was some forum that does that. Is this possible with Kunena?
rich wrote: Kunena works with JomSocial. You don't need a special Kunena version.
Time to create page: 0.242 seconds
