Question Upgrade from 4.0 11
9 years 6 months ago #185711 by Oscarfishlover
It's about time I upgraded. However, I can't find any straightforward instructions on how I upgrade from my current version.
The #1 Oscar Fish website on the net
Joomla! 2.5.14
Kunena 3.0.2
9 years 6 months ago #185712 by 810
Replied by 810 on topic Upgrade from 4.0 11
Just update Joomla,then update kunena by the Joomla update, else download the package then install
9 years 6 months ago #185718 by Oscarfishlover
Replied by Oscarfishlover on topic Upgrade from 4.0 11
Okey dokey, so it's just a case of upgrading to Joomla! 3.7 and then I will be able to upgrade to kunena 5?
Joomla! 2.5.14
Kunena 3.0.2
9 years 6 months ago #185721 by 810
Yes, its also working on older joomla versions, but there are some security fixes released, so i suggest to update joomla also.
9 years 6 months ago #185724 by Oscarfishlover
Where can I download a version of 4.0.12? I want to install it on another website and then test upgrading to 5.0. I don't want to do it on my main website that use the forum in case something goes wrong and I toast the forum completely
Joomla! 2.5.14
Kunena 3.0.2
9 years 6 months ago #185726 by rich
Replied by rich on topic Upgrade from 4.0 11
github.com/Kunena/Kunena-Forum/releases
Yes it's better to try it on a duplicate of your web page. So you can test and adjust the new installation. Kunena 5.0 series includes not anymore the Blue Eagle template and the style of Crypsis template is not the same.
