Question Search Engine Friendly URLs & RSS
9 years 7 months ago #184800 by Gamer Templates
Hi, since the latest two versions of Kunena, on my site the "Search Engine Friendly URLs & RSS" do not work.
Problem: www.gamer-templates.com/board/index.html
WITH Search Engine Friendly URLs in Kunena ON: Click RSS ICON -> the the RSS link is: www.gamer-templates.com/board/news.feed
WITHOUT Search Engine Friendly URLs in Kunena ON: RSS link works fine: www.gamer-templates.com/board.feed?view=...yout=default&catid=6
htaccess: Exists | PHP environment: Max execution time: 180 seconds | Max execution memory: 100M | Max file upload: 8M
Joomla default template details : rt_vermilion | author: RocketTheme, LLC | version: 1.4 | creationdate: December 4, 2015
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.7 | creationdate: 2017-03-31
Kunena template params:
Kunena version detailed: Kunena 5.0.7 | 2017-03-31 [ Gayal ]
Plugins: None
Any idea? Greetings from germany...
9 years 7 months ago #184814 by rich
You had Kunena 5.0.5 previously? I've tested it, the bug exists already with Kunena 5.0.6 if you have seo setting "Adds Suffix to URL = Yes". I've added it in the bug list now.
The following user(s) said Thank You: Gamer Templates
9 years 7 months ago #184823 by Gamer Templates
rich wrote: You had Kunena 5.0.5 previously?
Yes.
rich wrote: I've tested it, the bug exists already with Kunena 5.0.6 if you have seo setting "Adds Suffix to URL = Yes". I've added it in the bug list now.
I have the problems after update to Kunena 5.0. So the bug is older than 5.0.5
Thanks for report the bug :-)
Time to create page: 0.158 seconds
