Solved IMG-BB-Code does not work!
9 years 8 months ago #184287 by kunenatestit
entering a BB Code like
http://domain.com/index.php/gallery/image?view=image&format=raw&type=img&id=1
in a posting in kunena forum does not show up the image generated by
domain.com/index.php/gallery/image?view=...at=raw&type=img&id=1
Entering the URL above in a browser directly works!
And here in your forum it works too!
What am I making wrong?
Thanks and best regards
kunenatestit
9 years 8 months ago #184294 by rich
Replied by rich on topic IMG-BB-Code does not work!
This is not a image address. It lacks the directory path to the image such as /image.jpg.
Click with the right mouse on a image and copy the image path. Then try it with this address.
9 years 8 months ago - 9 years 8 months ago #184296 by kunenatestit
You are wrong: An image does not need to be requested via /image.jpg.
Like mentioned before the same URL entered in THIS kuena forum here does work properly and returns the right image.
So it must have to with configuration settings. But which ones? It is not an attachment so the the suffix list for image types etc. in kunena is not relevant.
Best regards
kuenatestit
Last edit: 9 years 8 months ago by kunenatestit.
9 years 8 months ago #184299 by rich
Where you see that? I cannot see a image.
9 years 8 months ago - 9 years 8 months ago #184300 by kunenatestit
9 years 8 months ago #184301 by rich
Thanks, but without your link to the picture I could not test it.
Go in the Kunena configuration to the tab BBCode and select "Display Images With Non-standard File Extensions = Image"
The following user(s) said Thank You: kunenatestit
