- Thank you received: 1
Solved IMG-BB-Code does not work!
- kunenatestit
- Junior Member
entering a BB Code like
http://domain.com/index.php/gallery/image?view=image&format=raw&type=img&id=1
in a posting in kunena forum does not show up the image generated by
domain.com/index.php/gallery/image?view=...at=raw&type=img&id=1
Entering the URL above in a browser directly works!
And here in your forum it works too!
What am I making wrong?
Thanks and best regards
kunenatestit
- Thank you received: 2545
This is not a image address. It lacks the directory path to the image such as /image.jpg.domain.com/index.php/gallery/image?view=...at=raw&type=img&id=1
Click with the right mouse on a image and copy the image path. Then try it with this address.
- kunenatestit
- Junior Member
Like mentioned before the same URL entered in THIS kuena forum here does work properly and returns the right image.
So it must have to with configuration settings. But which ones? It is not an attachment so the the suffix list for image types etc. in kunena is not relevant.
Best regards
kuenatestit
Where you see that? I cannot see a image.Entering the URL above in a browser directly works!
- kunenatestit
- Junior Member
Go in the Kunena configuration to the tab BBCode and select "Display Images With Non-standard File Extensions = Image"
