Question A couple of little things I need help with
9 years 7 months ago #184252 by Belazarus
Hi all
I hope you can assist with 2 little issues i'm having.
I've installed and configured my Kunena forum, and now I'm having trouble finding a couple of settings.
1. I'd like to remove the little title which appears next to topic creators which says "Topic Author". This appears next to the avatar image of the person who has created the thread. I can't find how to remove it from displaying.
2. I'd also like to remove the "More" button which appears underneath each user who has posted in the forum, clicking the "More" button then displays total posts, thank you's received, and a link to PMS message them. I just want this information to always display by default, without the need to press a "More" button.
I'd greatly appreciate any help I can get with this.
Thanks!
Tom
9 years 6 months ago - 9 years 6 months ago #184269 by rich
You need to create a template override. docs.kunena.org/en/faq/template-overrides
Both options are in the default.php in "components/com_kunena/template/crypsis/layouts/user/profile/"
Last edit: 9 years 6 months ago by rich.
9 years 6 months ago #184519 by Diaspro
Belazarus wrote: Hi all
Hi, i search for this "request" too, can someone reply me here or i need to open new post?
9 years 6 months ago #184555 by 810
1) Add de follow css on the custom.less
.topic-starter { display: none; }
2) add the follow css on the custom.less
.profile-expand { display: none; }
9 years 1 month ago #194891 by Belazarus
Thank you for your help with the above.
Could you please advise what css I would need to add, to still have the "total thank yous" be displayed here?
thanks!
Time to create page: 0.242 seconds
