Question problem with the Subscriptions
9 years 8 months ago #184187 by Nikiniko
the Check Subscription Box is set to no
prnt.sc/ef26gf
but members are still receving emails like is set to yes.
Any idea why it happens this ?
How to fix it ?
9 years 8 months ago #184196 by rich
Replied by rich on topic problem with the Subscriptions
Is the checkbox bellow the text field nevertheless marked? If yes, check in your profile the setting "Profile -> Edit -> forum settimg -> Select subscription as default".
You can unsubscribe unwanted subscriptions in the profile -> tab Subscriptions.
9 years 8 months ago #184217 by Nikiniko
The problem is not to unsuscribe,
The problem is that members dont want to receive mails with out to suscribe.
Can you help with that ?
9 years 8 months ago #184222 by rich
Users get only mails when topics or categories are subscribed. A subscription can happen accidentally, if the checkbox is marked as default. But you have set this option in the backend to No. Therefore I had written:
>> "Is the checkbox bellow the text field nevertheless marked? If yes, check in your profile the setting "Profile -> Edit -> forum settings -> Select subscription as default". <<
Which option is set in the profile? It should be the option „Default“ also here.
9 years 8 months ago #184356 by Nikiniko
Is it possible to set everything to no ?
Because people must go to profile set it to no and after they must unsubscribe from all topics that they were subscribed automatically.
9 years 8 months ago #184361 by rich
You can do it in the database. Please read this topic: www.kunena.org/forum/k4-0-kunena-support...ibing-users-to-topic But this changes only the profile setting. Unsubscribe must the user himself.
But it amazes me, that your users notice this now. It was a bug few months ago.
