Question Moderate Topic / Move Options
9 years 9 months ago #183800 by kensikora
I have installed Blue Eagle 5 to a forum and when I attempt to moderate a topic, the Move Options tab does not click. I'm sure it has something to do with my main template causing the conflict. The question is, how do I figure out what is the solution.
The template was created using Artisteer and I'm posting the same question in their forum. However, is there a tool that might tip me off as to what is the cause?
If a moderator wishes to login, please pm me.
The new forum is at fiberglassics.net/demo/forum/2-main-forum.html
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : Fiberg7b4 | author: Ken Sikora | version: 7b | creationdate: 2016-12-20
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.0.3 | creationdate: 2017-02-04
Kunena template params:
Kunena version detailed: Kunena 5.0.6.1 | 2017-01-28 [ Falanouc ]
Third-party components: CommunityBuilder 2.1.2+build.2017.02.08.01.14.28.ec3d63d1f
Plugins: None
