Question Can I disable hover button?
9 years 9 months ago #183695 by jurreman
I am using Joomla 3.6.5 and the latest version of Kunena. I use a Schoolfun free template and for Kunena I use Crypsis.
Everythings works fine. The only problem are the buttons. When I hover they become white on the bottom. Is there a way I can disable hover? I know that Crypsis3 is not using hover for the buttons, but it is not looking good with my template.
Is there a way to disable hover? Maybe in the custom.less?
