Question blank preview
9 years 9 months ago #183630 by kensikora
blank preview was created by kensikora
On our test forum at fiberglassics.net/demo/forums/fiberglassics-forums.html the preview box is empty when you hover over a forum. Any suggestions are appreciated on how to fix that.
9 years 9 months ago #183645 by 810
Replied by 810 on topic blank preview
Which kunena version are you running, i think it should work already on the latest version 5.0.6.1
9 years 9 months ago #183650 by GODpleasers
Replied by GODpleasers on topic blank preview
810 wrote: Which kunena version are you running, i think it should work already on the latest version 5.0.6.1
This has bean a issue with us from the beginning of 5.0. I was determined that Adds Suffix to URL was causing it. The fix that worked was right here. github.com/Kunena/Kunena-Forum/pull/4403/files
At any rate for some reason that fix is missing from the new releases of K5 and when we manually apply it to all the new releases it works fine.
If their is another way to do it please do it for us cause we are totally lost.
9 years 9 months ago #183652 by 810
@Godpleasers
What i want to do is, make a full backup of your site, then i will set the site on my localhost, so i can investigate the issue.
Is that ok for you?
9 years 9 months ago #183653 by GODpleasers
810 wrote: @Godpleasers
Is that ok for you?
:woohoo: Yes that is fine do you still have the testing2 username?
:unsure: I think the password is the same let us know if its not. Or if you need anything again.
9 years 9 months ago #183654 by GODpleasers
Is that ok for you?
We can also give WHM root access if you need it. Please let us know.
