Question Is it possible to make avatars visible to members only like with images ?
9 years 8 months ago #182695 by Nemo10
Is there anyway to only let members see avatars? Or remove the option completely?
Oh for a neat solution...
9 years 8 months ago #182699 by rich
Backend -> Kunena -> Plugins -> Kunena - Kunena Integration -> Basic -> Enable Kunena Avatars = No
9 years 8 months ago - 9 years 8 months ago #182700 by rich
Addition: If you set this plugin for Registered, then only logged in users can see the avatars.
Last edit: 9 years 8 months ago by rich.
9 years 8 months ago - 9 years 8 months ago #182707 by Nemo10
Thanks Rich..
What is the plugin you refer to? At this stage all viewers see the avatar if set. I can't see anywhere to set itto registered like you say.
Last edit: 9 years 8 months ago by Nemo10.
9 years 8 months ago #182712 by 810
kunena - kunena plugin there you can turn off avatars for everyone
Time to create page: 0.211 seconds
