Solved How to change Thank You icon to green?
However the light blue of the resultant icon is very lacklustre and would be better, I feel, in a warmer colour. Maybe even orange?
And the icon itself looks more like a trashcan which is not complimentary :blink:
Can it be fixed?
Is there a piece of code I can use to achieve this?
Oh for a neat solution...
- Thank you received: 2538
This icon is only for moderators so he can remove the thank you with it.And the icon itself looks more like a trashcan which is not complimentary
All's well except those so-called "trashcans" are still showing after the givers name.
I can only guess which icon you use on your page. Seems, it's a b2 icon. Try this:
But hey, since you pointed it out I don't see it as a registered member only, and that's the main thing. I'd still like to not see it at all as it beats me why a moderate would ever want to remove a thank you anybody made since it is hardly offensive, quite the opposite! But, I not wanting to appear too picky or unthankful so I can live with it.
I left out the bit of code so that the UNTHANKYOU is inconspicuous. All up, well done!
Yes I know it, Kunena 5.0 shows the icons. But there are differences between Joomla templates. Some templates support b2 icons, other templates b3 or font awesome icons. Therefore I could only help you if I can see the code on your page. But it needs minimum a moderator account, to see the trash symbols.I never added a trashcan icon
Have you tried with !important ?
In principle you are right. This option makes only sense if spammers haphazard to click on thankyou buttons.I'd still like to not see it at all as it beats me why a moderate would ever want to remove a thank you anybody made since it is hardly offensive, quite the opposite!
