- Thank you received: 1
Solved K 2.0.0 RC2 Settings Errors
For now there is a problem with the configuration of the forum. In basic settings, if i try to put the forum offline, set to yes, gives the following error and I can no longer access the Kunena component.
"Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@...... and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
I try in live site and in local computer with xampp, same error. In local computer an adicional error
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 261904 bytes) in C:\xampp\htdocs\sabores\libraries\joomla\plugin\helper.php on line 118
Issue itself has been fixed, thanks for the report.
