- Thank you received: 4
Question Faulty xpath parameter causes installation crash
Is this already a known and easily-corrected issue, or should I just give up and go back to 1.7 ?
By the way, "RC" is a little premature, don't you think? By your own admission you are expecting and warning against bugs, and you even recommend not to use the software for its normal, intended use! Well, that's what a Beta release indicates.
What are the steps to reproduce this issue ?
xillibit wrote: What are the steps to reproduce this issue ?
Well, I can tell you what steps I took:
Scenario: Latest Kunena already installed and operating correctly on latest Joomla.
1. Removed all Kunena menus (because I had read this might be a good idea);
2. Uninstalled Kunena system via Extension Manager : Uninstall
3. Installed K2.0 via Extension Manager : Upload
The aforementioned message appears midway through the installation.
Does the Kunena installer assume "/home/" paths, by any chance? Mine was recently changed to "/home1/," which has tripped up a few applications.
Your issue can only be triggered with broken Kunena template, but thanks for the report -- we will fix it.
