Question Avatar and RTL language problems with my template
13 years 7 months ago - 13 years 7 months ago #142088
by poonoodi
Avatar and RTL language problems with my template was created by poonoodi
hi
i do updated my forum to latest version
but
don't show users avatars after updated
and
the new version don't support RTL language
please help
Regards
but
and
please help
Regards
Last edit: 13 years 7 months ago by poonoodi.
The topic has been locked.
13 years 7 months ago #142093
We get many questions every week about problems that people have with avatars. Most of these questions can generally be answered within a very small amount of time if people include their Kunena configuration report at the same time as they ask their question. When people do not include their configuration report in these kinds of cases, we have to ask for the report and then wait for the reply and then we're in a better position to try to figure out what people may have done and what they may need to do based on that information.
So my suggestion to you is to do one of two things:
1) Try using the K 2.0 Blue Eagle template and then post your configuration report to us; or
2) Contact the people who designed the template you are using and ask them if that template works in K 2.0.4.
Replied by sozzled on topic Avatar and RTL language problems with my template
K 2.0.4 does support RTL but it's possible that the template that you have chosen does not support K 2.0.4.poonoodi wrote: the new version don't support RTL language
The following user(s) said Thank You: poonoodi
13 years 7 months ago - 13 years 7 months ago #142114
by poonoodi
Replied by poonoodi on topic Avatar and RTL language problems with my template
Hi
I install new template and RTL problem solved.
but
Avatar does not show in defult template (K 2.0 Blue Eagle)
Regards
but
Regards
13 years 7 months ago #142135
by poonoodi
problem with avatar solved
i have new problem with Kunena Latest Module
this module don't work properly
module don't show new topic or post
the old version worked properly in my site
Regards
Regards
13 years 7 months ago #142138
This topic is now closed.
Good. This topic is now solved.poonoodi wrote: problem with avatar solved
New problem, different subject.poonoodi wrote: i have new problem with Kunena Latest Module
