Question Kunena 2.0.3 problem with alignment topic icons and emotions
13 years 4 months ago - 13 years 4 months ago #138803 by gretagaia
Hi I have a problem with the alignment of icons topic and emotions with the template you want to use qundo enter a post icons appaione as shown in figure A and with other template all right as shown in Figure B, how can I fix this? which files I need to edit the template in use? Thank you.
www.allevamentodabruzzo.it
Last edit: 13 years 4 months ago by gretagaia.
The topic has been locked.
13 years 4 months ago #138820 by Philip Bainbridge
Ig you paste a link to your site maybe someone could try and help resolve the problem.
I would imagine maybe a css conflict.
13 years 4 months ago #138821 by gretagaia
13 years 4 months ago - 13 years 4 months ago #138823 by sozzled
The problem is that, in order to see the problem, one needs to be creating/editing a message on the forum. In order to do that, in this case, one needs to login to the site. Do you have a test account that we can use to login to the site in order to see what is going on here?
Yes, the solution involves changing the CSS. Alternatively, the solution involves using a different Joomla site template. It all depends on how much time you want to spend working on adapting your Joomla site template so that it does not mess up Kunena. See the category description - the notes printed at the top of this page - for background reading about how to handle the matter "My Joomla site template makes a mess of Kunena".
Last edit: 13 years 4 months ago by sozzled.
13 years 4 months ago #138826 by gretagaia
which css file I need to change? the template in use is Shape5-Soul Search
13 years 4 months ago #138831 by Philip Bainbridge
Check your forum i may be able to help.
