Solved SOLVED: #ktab CSS issue.
13 years 5 months ago - 13 years 5 months ago #138333 by stanne
Hello everyone, I hope someone can help with this issue.
I'm using Blue Eagle with no modifications. It is picking up formatting from my template.css which puts a bullet in front of a <li>. I'm using it elsewhere on my site, and want to keep it. If I use Firebug, and change the html ouput from <li> to <ul>, the bullets go away.
I need to find where the hook is so the tabs wil use the <ul> automatically rather than the <li> formatting. I went through the kunena.forum-min.css file and changed every li to ul that was attached to the #ktab to see if it would change, but no luck.
Can someone point me in the right direction. Small screenshot is attached to show what I am talking about. TIA.
Stan
Last edit: 13 years 5 months ago by stanne. Reason: Solved
13 years 5 months ago - 13 years 5 months ago #138335 by Josh
Replied by Josh on topic #ktab CSS issue.
A link to your site (forum) would help a lot. I am a big fan of firebug and could probably figure this out in a jiffy. :)
Last edit: 13 years 5 months ago by Josh.
13 years 5 months ago #138339 by stanne
Replied by stanne on topic #ktab CSS issue.
Thanks for the help. The site is stannellc.com
13 years 5 months ago #138357 by TKtemp
Replied by TKtemp on topic #ktab CSS issue.
you cannot change li -> ul, it is wrong.
Try instead to add this few lines at the end of your Joomla Template css file (template.css)
#Kunena #ktab li:before { content: ""; }
13 years 5 months ago - 13 years 5 months ago #138359 by Josh
Personally I prefer this one:
#Kunena #ktab li:before {content: none;}
(add this to your main template)
I tested the above post with firebug with the quotes which ended up with a weird result.
The following user(s) said Thank You: stanne
13 years 5 months ago #138369 by stanne
Thanks, worked like a charm. So focused on changing what was there, I never thought of that.
Time to create page: 0.255 seconds
