Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Solved [ Solved] Creating my own template with Blue eagle 2.0 as base - Issue right after cloning.
13 years 3 months ago - 13 years 3 months ago #137336
by iLucato
[ Solved] Creating my own template with Blue eagle 2.0 as base - Issue right after cloning. was created by iLucato
Hi folks, I have duplicated the content of the blue_eagle folder (/components/com_kunena/template/blue_eagle) and named the other folder to my_theme (/components/com_kunena/template/my_theme). Right after doing that and selecting my_theme into the template manager, it doesn't get to read the CSS files.
It is a clone of the blue_eagle folder. How do I get to make "my_theme" selected into the manager get to read the CSS? The weird thing is if I select EDIT CSS, it shows the right path "/components/com_kunena/template/my_theme/css"
Any help will be appreciated.
Last edit: 13 years 3 months ago by iLucato.
13 years 3 months ago #137339
Replied by sozzled on topic Creating my own template with Blue eagle 2.0 as base - Issue right after cloning.
You need to modify the XML file and the initialiation.php file
13 years 3 months ago - 13 years 3 months ago #137351
by iLucato
Replied by iLucato on topic Creating my own template with Blue eagle 2.0 as base - Issue right after cloning.
Hi Sozzled, any idea what should I exactly modify? I mean, at initialize.php I found the variable that seems already call the folder automatically with the "{$app->getTemplate()}" as shown below:
"templates/{$app->getTemplate()}/css/kunena.forum.css"
where on the begin of the code the variable is set as:
$app = JFactory::getApplication();
$document = JFactory::getDocument();
$template = KunenaFactory::getTemplate();
Just as a comment, the only line that really has blue_eagle written in the path that I should change, was the line 48. Not sure if the code should have something like {$app->getTemplate()} instead of blue_eagle.
All other paths are set as "/components/com_kunena/template/{$template->name}/media", so the {$template->name} seems to read from somewhere my folder.
So that is why I'd like to know what exactly should I change at initialize.php? At xml, just seems to change description and template name.
[Edit]
Just adding, the path I mentioned "templates/{$app->getTemplate()}/css/kunena.forum.css", where is the main template of the site not kunena, doensn't have the path /css/kunena.forum.css. So, what I mean is when installing Kunana, it doesn't install any css into "templates/" folder as the path shown, but into the "/components/com_kunena/template/my_theme/css"instead.
Well, puzzled once I'm not a programmer.
[/Edit]
[Edit]
[/Edit]
13 years 3 months ago #137352
Did you read, in the Wiki, how to create a template?
13 years 3 months ago #137354
by iLucato
Yes, and just got to solve it.
There is no need to change the initialize.php, just the template.php at line #12
class KunenaTemplateBlue_Eagle extends KunenaTemplate {
to:
class KunenaTemplateMy_Template extends KunenaTemplate {
Now, just the left doubt is if in this same file where is the:
// Try to find missing files from the following parent templates:
protected $default = array('blue_eagle');
Should I change to
protected $default = array('My_Template');
Any idea? Thanks
to:
Should I change to
Any idea? Thanks
The following user(s) said Thank You: BamiGorengo
Time to create page: 0.283 seconds
