Solved Kunena code frame
14 years 4 months ago #128077 by logk123
Kunena code frame was created by logk123
Hi there, i am using latest kunena, i have a question, how can I change the code frame (border) at the moment it's really ugly bolded red, is there something like ready "code templates" because no matter what kunena template i use, it stays the same. Thanks in advance
14 years 4 months ago - 14 years 4 months ago #128079 by sozzled
Replied by sozzled on topic Kunena code frame
I do not know what Kunena template you are using but I believe the issue is caused by your Joomla site template CSS. Please read My Joomla site template makes a mess of Kunena .
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago #128081 by logk123
Replied by logk123 on topic Kunena code frame
yes you are right, any idea how to fix it thoguh?
14 years 4 months ago #128088 by sozzled
Without knowing anything about your website, the answer to your question is "I know the general approach - which I've referred to in My Joomla site template makes a mess of Kunena but the specific answer depends on knowing about your website and what this situation looks like there.
Do you have an example - a URL of a page that illustrates the issue - to give us? :dry:
14 years 4 months ago #128110 by logk123
yeah
14 years 4 months ago #128186 by sozzled
Pretty pink frames ... but where can we see them? I asked for the URL of an example, not screen captures. When we have the URL information then we will be able to help (see What information should I include when I ask for help (including how to post my configuration report)? . If you do not want to give us the URL of your website, that's OK. We don't have to help you; you can use Firebug and do the job just as well yourself. ;)
