Solved Hide columns (topics, replies) from main forum index
14 years 3 months ago - 14 years 3 months ago #127565 by Nothing
Hi.
Is it possible to disable the Topics and Replies column?
Last edit: 14 years 3 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes; change topic icon
14 years 3 months ago #127580 by coder4life
No it is not possible to remove topic and replies through a configuration option. However you can achieve this through some CSS.
14 years 3 months ago #127703 by Nothing
Yeah....i thought about that ^^
Can you tell me how to remove that?
14 years 3 months ago #129266 by coder4life
Are you comfortable editing files?
14 years 3 months ago #129276 by Nothing
Yep. Sure. I tried a lot...but with no result.
14 years 3 months ago - 14 years 3 months ago #129279 by sozzled
You need to add the following lines to the end of your Joomla site template CSS file:
#Kunena td.kcol-kcattopics, #Kunena td.kcol-kcatreplies { display: none; }
Perhaps you might also like to donate a dollar to the Kunena project for the time it took us to answer your request. ;)
The following user(s) said Thank You: Nothing
