Solved Kunena too wide for template...
14 years 4 months ago - 14 years 4 months ago #127456 by fribse
When I try out our new J2.5.6 template, Kunena does not scale fully down.
Any input on this?
Best regards
Fribse
Dykkerklubben Dannebroge www.dkdb.dk
We're a volunteer driven diving club in Mosede, Denmark.
Har du brug for en dykkerklub der rummer alle, så kom ned til os.
Last edit: 14 years 4 months ago by fribse.
14 years 4 months ago - 14 years 4 months ago #127502 by sozzled
What Kunena template are you using? Your K 2.0 configuration report will give us that information.
Please also read My Joomla site template makes a mess of Kunena .
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago - 14 years 4 months ago #127553 by fribse
I'm using the Blue eagle 2.0
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : at_cesmiro | author: atjoomla | version: 2.5 | creationdate: 2012-05-30
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.0 | creationdate: 2012-06-27
Kunena version detailled: Kunena 2.0.0 | 2012-06-27 [ Diplomatia ]
| Kunena detailled configuration:
| Joomla! detailled language files installed:
Third-party components: CommunityBuilder 1.8.1 | UddeIM 2.8
Plugins: Search - Kunena Search 1.7.2
Modules: Kunena Stats 1.7.2
Best regards
Fribse
Last edit: 14 years 4 months ago by fribse. Reason: Wrong config displayed
14 years 4 months ago #127554 by fribse
I found it, I was looking at the wrong css, I was looking at the individual cells, but it's set in the
kunena.forum-min.css
There's is a setting of
#Kunena {min-width: 700px;}
I set a
min-width:600px!important;
in the template.css, and that fixed it.
I guess I could put it in template/html to make an override, but I have no idea what the path for that should be???
Best regards
Fribse
14 years 4 months ago #127677 by Matias
We have minimum width because of not everything fits into the screen if you have less than that. It would be safer to remove left and/or right module position from Kunena pages (if you have those). Or make your template slightly wider.
14 years 4 months ago #127724 by sozzled
I looked at the website ( test.dkdb.dk/forum/oversigt.html ) and I cannot see the problem. Therefore I assume this has been fixed.
