Solved No side panel and buttons with no title
14 years 4 months ago - 14 years 4 months ago #127243 by Lionheart
I have a problem with titles in buttons showing `com_kunena_button_topic_reply` etc. Picture below explains everything.
And next; Side panel with avatar not showing in post when logged in, it shows when logged out thou
Help!
Last edit: 14 years 4 months ago by sozzled. Reason: Change topic icon to "solved"
14 years 4 months ago #127309 by Lionheart
Issue sorted...........
14 years 4 months ago #127312 by Mortti
When you solved your problem you should tell that how? Even it's so easy that I think so?
14 years 4 months ago #127330 by Lionheart
I installed Kunena 2 on top of 1.7.2 as in upgrade, bad idea, so reinstalled clean kunena 2 and now fixed. Also deleted old menu and used new menu......
