Solved Automaticaly add an joomla article into forum
14 years 4 months ago - 14 years 4 months ago #127450 by HardstylerDK
Hi everybody,
I've got a problem which i hope you can help me with.
When i write an article in joomla, i would like it to be place in a specified category in the Kunena forum.
Is there any way to do this ? I know it can be done if youre using vBulletin, but i rather use Kunena!
Last edit: 14 years 4 months ago by sozzled. Reason: Change topic icon; move topic to more appropriate category
14 years 4 months ago #127480 by HardstylerDK
Isnt there anybody who knows how to do it ?
14 years 4 months ago #127522 by coder4life
Can you please clarify?
Do you mean you want to use Kunena as a discussion system for the Joomla article?
14 years 4 months ago #127546 by HardstylerDK
coder4life wrote: Can you please clarify?
Yes like that! :)
At my old site, when we wrote an article in joomla backend we had an dropdown menu where we first could choose for example "Reviews" and the another dropdown menu where we would choose the submenu like "Headphones", and then when we published the review it would put a copy of it into our forum.
Does that makes sense ? :)
14 years 4 months ago #127640 by Matias
Check Kunena Discuss plugin.
14 years 4 months ago #127689 by HardstylerDK
Matias wrote: Check Kunena Discuss plugin.
Will that plugin do the that ?
