- Thank you received: 1
Question Install problem kunena on joomla 2.5.9
13 years 8 months ago #141205
by LeonZ
Install problem kunena on joomla 2.5.9 was created by LeonZ
I have migrated severall joomla 1.5 sites to the latest Joomla 2.5 versions without a problem. Now busy with a website running Kunena and get headaches upgrading Kunena.
So to level the error I tried to install Kunena on a clean Joomla 2.5.9 website. I have no warnings, it's running apache with fastcgi module.
All system requirements are there but when trying to install I get the following error in the log and after several days of searching for a solution and rebuilding the test site I am kind of desperate.
The error is:
The line differs depending on which version of Kunena I try to install
com_kunena_v2.0.4_2013-01-18
Can someone point me in the right direction again ?
The error is:
mod_fcgid: stderr: PHP Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in /var/www/vhosts/mywebsite.nl/httpdocs/administrator/components/com_kunena/install/model.php on line 1551, referer: http://mywebsite.nl/administrator/index.php?option=com_installer
The topic has been locked.
13 years 8 months ago #141243
by xillibit
Replied by xillibit on topic Install problem kunena on joomla 2.5.9
The file seems to be corrupted. How do you proceed to install ? By giving package, by putting url ?
13 years 8 months ago - 13 years 8 months ago #141251
by LeonZ
Replied by LeonZ on topic Install problem kunena on joomla 2.5.9
I tried every possibility. Even install by URL give me the error. Driving me nuts really.
I just performed an upgrade on the live site with jupgrade, turned everything off and tried to install Kunena by URL immediately. Same error in log and ending in white screen.
Checking the database there are kunena entries in the menu and in the extensions. Furthermore no kunena tables.
In the Joomla admin, I notice the Kunena menu but upon clicking getting the famous white screen. Error stays on line 1551 in model.php
After this tried installing as an example acymailing latest version and without errors.
Last edit: 13 years 8 months ago by LeonZ.
13 years 8 months ago #141256
by LeonZ
and another try cleaned database cleaned directory, didn't bother upgrading joomla to 2.5.9 son on joomla 2.5.6
max_execution_time = 120
memory_limit = 64M
safe_mode = off
upload_max_filesize = 8M
GD, DOM, JSON support installed
Database Version 5.0.95
Database Collation utf8_general_ci
PHP Version 5.3.8
Web Server Apache
WebServer to PHP Interface cgi-fcgi
Joomla! Version Joomla! 2.5.6 Stable [ Ember ] 19-June-2012 14:00 GMT
memory_limit = 64M
safe_mode = off
PHP Version 5.3.8
Web Server Apache
13 years 8 months ago #141257
by LeonZ
Sorry, another try, debug joomla turned on. Kunena latest version downloaded, cleaned everything again, put by directory.
Debug notification:
Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in /var/www/vhosts/mysite.nl/httpdocs/jupgrade/administrator/components/com_kunena/install/model.php on line 1551
Call Stack
# Time Memory Function Location
1 0.0003 675168 {main}( ) ../index.php:0
2 0.0783 7657344 JAdministrator->dispatch( ) ../index.php:46
3 0.0829 8188648 JComponentHelper::renderComponent( ) ../application.php:153
4 0.0892 8198320 JComponentHelper::executeComponent( ) ../helper.php:351
5 0.0896 8251872 require_once( '/var/www/vhosts/mysite.nl/httpdocs/jupgrade/administrator/components/com_kunena/admin.kunena.php' ) ../helper.php:383
6 0.0979 9497736 KunenaControllerInstall->__construct( ) ../admin.kunena.php:33
Debug notification:
Call Stack
13 years 7 months ago #142178
by LeonZ
I really don't want to bump my topic, but really after four weeks ????
Can some expert really read this topic and tell me what is wrong, and don't tell me it's just a corrupt file because it means nobody uses Kunena cause I download it from this site, I install by URL from this site etc. etc. with new downloads etc.
TIA
Leon
TIA
Leon
