Question Which should be upgraded first?
14 years 2 months ago #132941 by dianaNashif
Getting ready to upgrade Kunena to 2.0.2 from 1.7. I also need to upgrade my jomSocial to 2.6. Can you tell me should I upgrade JomSocial first and then Kunena or the other way around?
Kindest Regards,
Diana
14 years 2 months ago #132943 by xillibit
I advise to upgrade in first jomsocial, and others third party components and then Kunena.
14 years 2 months ago #132945 by dianaNashif
JomSocial said this right after Kunena 2.0 came out.
Kunena 1.7.2 is not fully compatible with JomSocial 2.6.2 so you'd have to upgrade to kunena 2.0
So I guess I need to take a step back and upgrade Kunena to 2.0, then upgrade JomSocial and then upgrade Kunena again to 2.0.2.
Darn, should of upgraded when I received a notification from Kunena the first time!
Diana
14 years 2 months ago #132946 by dianaNashif
Can you tell me where to download version 2.0? I have a copy of 2.0.1 and 2.0.2 but not 2.0 as I thought I did.
Thank you,
Diana
