Solved K 1.7.2 to K 2.0.1: upgrade hangs at "Recounting forum statistics ... OK"
14 years 1 month ago #129786 by fgossart
my upgrade stops when recounting forum statistics
Event if I click next many times, it's still at the same state.
What can I do ?
Prepare Installation ... OK
Uncompressing com_kunena-admin.zip ... OK
Uncompressing com_kunena-site.zip ... OK
Uncompressing com_kunena-media.zip ... OK
Installing System - Kunena plug-in ... OK
Installing Quickicon - Kunena plug-in ... OK
Installing Kunena - Alphauserpoints plug-in ... OK
Installing Kunena - Community plug-in ... OK
Installing Kunena - Comprofiler plug-in ... OK
Installing Kunena - Gravatar plug-in ... OK
Installing Kunena - Uddeim plug-in ... OK
Installing Kunena - Kunena plug-in ... OK
Installing Kunena - Joomla plug-in ... OK
Creating category aliases ... OK
Upgrading 1 menu items ... FAILED
Migrating configuration options to K2.0.0 schema ... OK
Converting read posts to K2.0.0 schema ... OK
Database upgraded to version 2.0.1 ... OK
14 years 1 month ago #129797 by sozzled
Seems like you have made some custom menu items that were unanticipated by the Kunena installer. Try removing all existing menu items that refer (in any way) to Kunena and attempt to run the installation again.
I'm not sure what else I can advise in this case. If I were in your situation, I would check (again) all the necessary preparations/precautions I had taken in K 2.0 Upgrade Guide and then, satisfied that I had done everything I could have done, I would uninstall Kunena and then attempt to re-install Kunena again.
14 years 1 month ago #130975 by Linus
Heureka!
That solved the issue for me! I deleted all the Kunena-Forum-menu items and the menu itself and after that it worked flawlessly.
I hope it solved your problem as well!
Time to create page: 0.236 seconds
