Kunena 7.0.8 Released
Solved Kunena 2.0 installation freezes on XAMPP 1.7.7
My case is very similar to this one:
www.kunena.org/forum/K-2-0-Installation-...freezes?limitstart=0
I´m restoring my website in a local test environment with XAMPP 1.7.7 before trying to upgrade to K 2.0.0
I upgraded my site succesfully to K 1.7.2 and Joomla 2.5.6. From there I tried to upgrade to K 2.0.0 but when the upgrade process reaches to this:
The update progress seems to stop.
The only way to go forward is clicking "next".
The next pictures are the progress clicking "next" after about one hour:
This is the last update progress:
After that no more progress.
What can be going wrong?
thank you in advance.
Though, it did work on my Xampp environment
(Xampp for Windows 1.7.3)
then I´m thinking uninstall 1.7.7 version and try to do upgrade with 1.7.3...
I´m going to compare the specs of both versions, and with my livesite server... to be sure its the correct version...
Anyway, probably I´ll wait to the next version of K 2.0.1 to upgrade the live site.
All I wanted was to test te upgrade before do it in my livesite, to make sure everything goes well.
Anyway, I tested the upgrade with XAMPP v 1.7.3 with the same results...
I think I´ll wait to the release of K 2.0.1 and then try to upgrade directly in livesite.
Something tells me that I´ll be back here by this point...
Thank you for yout answers, Linus & Sozzled.
See you soon
Who is "we"? This is a communty-driven self-help forum for Kunena. It is not a self-help forum for questions about XAMPP. We are not suggesting that Kunena will not work on PC-hosted websites; we are only saying that, because we cannot see your site then we cannot give people who use PC-hosted websites the same kind of help we can give to people who have problems on real (internet-accessible) websites. That's the message we are trying to get across to you.Wild Duck wrote: Ok, now I know you don´t give support to WAMPP XAMPP localhost installations
Joomla will run on XAMPP (or other PC-hosted or intranet) sites. By extension, Kunena will work on those sites, too. It doesn't matter if we are talking about K 2.0.0 or any other version of Kunena. The same advice holds true.
I hope that clarifies any misunderstanding that you may have about the support that we try to offer and the support that we are capable of offering to people who use PC-hosted or intranet sites where none of us has direct access to see what is going on there.
