Question Upgrade freezes
14 years 4 months ago - 14 years 4 months ago #127529
by Linus
Upgrade freezes was created by Linus
"Info: It is only seemingly frozen and ist still upgrading - but reeeeally slowly (1h so far)"
I am currently updating Kunena from 1.72 to 2.0.0 on Joomla 2.54 and the upgrade-progress froze after "Migriere Konfigurations-Optionen zu K2.0.0 Schema" (German)( which would be something like "migrating configuration settings to k2.0.0 scheme")
After patiently waiting for 10 minutes I clicked on "weiter" (next) and I noticed that another step was made, so I decided to stay patient. It's now been about one hour and the upgrade process ist still not completed. Any ideas why that is?
status: 1 hour to get to "Forumstatistiken werden gezählt" (calculating forum statistics)
Last edit: 14 years 4 months ago by Linus.
The topic has been locked.
14 years 4 months ago #127530
by Linus
Replied by Linus on topic Upgrade freezes
Before it slowed down it says: "Aktualisiere 1 Menüerweiterungen ... FAILED" (Updating 1 menuextension)
- coder4life
- Kunena Contributor
- Thank you received: 50
14 years 4 months ago - 14 years 4 months ago #127533
by coder4life
Replied by coder4life on topic Upgrade freezes
If you are using a different language for Joomla install, please translate to English the error messages. Also please include your configuration report.
Last edit: 14 years 4 months ago by coder4life.
14 years 4 months ago #127537
by Linus
I already included the approximate translations in brackets behind the copied text.
Ok,I will post the configuration report once the upgrading process is finished or has failed entirely (I hope it does finish at some point) - If I'd do it right now I'd loose my progress so far (1,5h).
- coder4life
14 years 4 months ago - 14 years 4 months ago #127540
by coder4life
@Linus, oh thanks, did not see it. I start reading 30+ topics and text starts to blend together
The upgrade process should take no more than a few minutes. I suspect something is stuck in the upgrade process. Is there a status about where you are at? Is it possible to post a screenshot?
14 years 4 months ago #127542
by Linus
ah, no worries - didn't even expect anyone to reply that fast
Nothing has changed so far. it's still on the statistics. I included a screenshot.
I already restarted the process two times (2h ago), when I thought it froze. But that obviously didn't help.
