Question Removed K1.7 und installed K2.0 but forum doesn't work!
14 years 5 months ago #127067 by kaju74
Hi.
I've deleted Kunena 1.7 from my website (latest Joomla) and installed 2.0 from scratch yesterday. As soon as I try to enter the forum from the frontpage, I'v get the following error:
Fatal Error was detected!
Fatal Error: Cannot pass parameter 2 by reference in components/com_kunena/lib/kunena.file.class.1.6.php on line 60
The error was detected in the Kunena Component.
For support click here: Kunena Support
I'm running PHP 5.3.12 and Joomla! 2.5.6 Stable.
Any idea?
Thank you,
Marc
14 years 5 months ago #127068 by 810
The following user(s) said Thank You: kaju74
14 years 5 months ago #127074 by kaju74
Thank you...it seems to work now 8-))
Regards, ...
14 years 4 months ago #127437 by sjr2012
kaju74 wrote: Hi.
Any idea?
Thank you,
Marc
Hi
I have exactly the same issue as above. The site is in build, so I am happy wait for a few weeks for a fix/upgrade, assuming one is in the pipeline, or would you recommend the quick fix posted anyway?
Thanks.
14 years 4 months ago #127439 by kaju74
Hi.
The workaround works fine for me B)
Regards,
Marc
14 years 4 months ago #127524 by coder4life
@sjr2012 Yes there is a fix in the works. We always recommend to wait for official releases, however those comfortable enough editing files can attempt any hotfixes that our Dev Team may provide.
The following user(s) said Thank You: sjr2012
