Question K 2.0.4 + J! 1.5.25: problem with new pages
13 years 3 months ago #147175 by vachos
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : rt_populus_j15 | author: rhuk | version: 1.0.0 | creationdate: 11/26/07
Third-party components: UddeIM 2.9
Plugins: JomSocial - My Kunena Forum Menu 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.4
Modules: Kunena Login 2.0.4
13 years 3 months ago #147178 by sozzled
1) You have the Joomla - Legacy plugin enabled! This is why you are having problems.
See Legacy mode in the Wiki.
Joomla never supported "legacy mode". Kunena is not tested on J! 1.5.x systems running with the Joomla - Legacy plugin enabled. You need to disable this plugin. Unless and until you remove legacy mode from your J! 1.5 site, this problem will never be resolved.
2) You should also use the Blue Eagle template designed for K 2.0.4, not the one designed for K 1.7.2.
3) You have the following plugins installed: JomSocial - My Kunena Forum Menu 2.0.4, JomSocial - My Kunena Forum Posts 2.0.4, JomSocial - Kunena Groups 2.0.4. You do not have any JomSocial installed. You should uninstall these plugins. You do not need them.
4) You should change your forum integration settings (see recommended settings shown in red below):
13 years 3 months ago #147179 by vachos
Thanks for help .
I make all the changes but nothing help the problem still there ! The problem begin when the site change server ! Maybe it's something else ?
13 years 3 months ago #147181 by sozzled
If you have made all the changes, please post your configuration report again so that we can see what changes you have made. Thank you.
13 years 3 months ago #147182 by vachos
It's ok ?
13 years 3 months ago #147183 by vachos
Iam uninstall jomsocial I don't know why it's show here :(
Time to create page: 0.165 seconds
