Question All broken after upgrade
13 years 5 months ago #144795 by duranie
I have upgraded an old strange version of 2.0.0-DEV to 2.0.4 and now every link is broken. In my Kunena-latest module I can see the topics but when I click one I get URL not found.
I can also see everything in the backend as I used to but the whole front is broken.
Any ideas??
Thanks.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 1024M | Max file upload: 5M
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 2.0.0-DEV | creationdate: 2011-07-21
Third-party components: Jomsocial 2.0.6
Plugins: None
Modules: Kunena Latest 2.0.0-DEV
13 years 5 months ago #144797 by skybax
Replied by skybax on topic All broken after upgrade
You use Kunena Latest 2.0.0-DEV you need to instal Kunena Latest 2.0.4
13 years 5 months ago #144798 by duranie
Replied by duranie on topic All broken after upgrade
That shouldn't affect the component it self, I think?
The latest module is actually the only thing that is working at the moment.
13 years 5 months ago #144800 by skybax
can you post a link to your forum?
and also try a reinstall over the current forum.
13 years 5 months ago #144801 by duranie
Unfortunately no link to the actual forum as it is on a closed stage environment. But I will try to reinstall version 2.0.4 again to see if this helps.
13 years 5 months ago #144803 by duranie
Reinstall didn't do anything. But it looked as if it just installed the files again and didn't do any DB update or so as it did the first time.
Did I read some where that there is a DB script to update these kind of errors?
Time to create page: 0.147 seconds
