Question How do I disable auto-subscription
13 years 6 months ago #143910 by TraaBBIT
Hi.
How disable auto subscription from Kunena configuration?
I don't want to sent message only if user want it, not when write in topic.
hygnhtyjkhtyutuy
13 years 6 months ago #143911 by sozzled
If you could provide your configuration report here, we should be able to give you the answer you need, Thank you.
13 years 6 months ago #143958 by TraaBBIT
Joomla default template details : yoo_revista | author: YOOtheme | version: 1.0.4 | creationdate: July 2012
Third-party components: UddeIM 3.0
Plugins: None
Modules: Kunena Latest 2.0.4 | Kunena Stats 2.0.4 | Kunena Login 2.0.4
hygnhtyjkhtyutuy
13 years 6 months ago #143963 by Matias
Yup, it was your configuration.
Kunena Configuration > Users > Subscriptions > Check Subscription Box = No
should fix your issue. Also check the other option in there.
Time to create page: 0.156 seconds
