Question View Replies
13 years 6 months ago - 13 years 6 months ago #143739 by chil
View Replies was created by chil
Upgraded to version 2 on test site.
If I log on as a guest and submit a reply, then I log on as admin to approve the post. When I logout again and view the category as a guest, I wont see the new posts until I clear cache and purge from Joomla backend.The weird thing is that if I hit 'reply' , I CAN see the last post.4 Is this related to session lifetime which is set to the default 18000?
Report attached.
Last edit: 13 years 6 months ago by chil. Reason: more info
13 years 6 months ago #143744 by sozzled
Replied by sozzled on topic View Replies
Where is the K 2.0. configuration report? I do not see it here.
13 years 6 months ago - 13 years 6 months ago #143749 by chil
Replied by chil on topic View Replies
Sorry, I have attached it again.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : ja_methys | author: JoomlArt.com | version: 2.5.0 | creationdate: February 2012
Third-party components: CommunityBuilder 1.9
Third-party SEF components: sh404sef 3.4.6.1269
Plugins: None
Last edit: 13 years 6 months ago by rich. Reason: Configuration report inserted
13 years 6 months ago #143801 by chil
hi
Do I need to add any more info?
13 years 6 months ago #143946 by Matias
Replied by Matias on topic View Replies
You're likely using Joomla page cache (System - Cache plug-in), which is for static sites with no changing content. It caches all pages that guests visit and there's no way to go around the plug-in because of some architectural limitations in it.
So disabling the plug-in should fix your issue.
