Question Uddeim plugin (Kunena) deleted
13 years 7 months ago #142886 by Oscar2
Hi!
I accidentally deleted the Uddeim intergration plugin from the Kunena plugins. Can I download it somewhere seperately?
13 years 7 months ago #142888 by xillibit
You can find the plugins into Kunena installation package, just extract it and install alone.
13 years 7 months ago #142891 by Oscar2
I copied the files inside the Uddeim folder to the site, but this doesnt work.
How can I install it?
13 years 7 months ago #142896 by sozzled
It is 100% easier to re-install Kunena. If you re-install Kunena you will lose nothing.
Your configuration will be unchanged, your forum categories will not change and your forum messages and attachments will remain intact.
Reinstall K 2.0.4 and your problems will be fixed. Takes about 30 seconds.
