Idea Joomla forum button not highlighted.
13 years 7 months ago - 13 years 7 months ago #142581 by robertbseattle
Not sure which forum to post this in but here it goes...
Basically when in Joomla I am using my main menu I click on DISCUSS menu item to load the Kenuna page and it works. BUT the button on my Joomla main menu that corresponds to the DISCUSS isn't highlighted to indicate that I'm on that page.
In contrast when I land on any other page that button is highlighted to notify the user where they're at. But not for Kenuna : /
Searched the forums and didn't come across any answers.
Last edit: 13 years 7 months ago by robertbseattle.
13 years 7 months ago #142678 by robertbseattle
OK I think I'm on to something.
When I hover over the menu item I notice it point to:
mysite/index.php/discuss
BUT when the page loads the site address bar is:
mysite/index.php/forum/index
I'm still learning but could this be part of it?
13 years 7 months ago #142693 by sozzled
robertbseattle wrote: I am using my main menu I click on DISCUSS menu item to load the Kenuna page and it works. BUT the button on my Joomla main menu that corresponds to the DISCUSS isn't highlighted to indicate that I'm on that page.
I have not seen this "DISCUSS" menu item that you are referring to so I really don't know how to assist you.
What would assist you is to read our FAQs . My guess is that the problem arises because of how you've defined your "DISCUSS" menu item. Can you give us more information on these things?
The following user(s) said Thank You: robertbseattle
13 years 7 months ago - 13 years 7 months ago #142735 by robertbseattle
Main menu > add new menu item...
Menu Item Type:
From the Kunena Forum list I select:
Home Page - build your menu under this page.
Default Menu Item:
I select Index from the dropdown menu.
Menu Title:
I name the menu DISCUSS
SAVE AND CLOSE
Now I go to my front end, click the DISCUSS menu item and the forum loads on the page, BUT it is not highlighted in the main menu bar. :blink: :side: :S (see attached)
Every other page I go to the menu is highlighted with a different color as my template specifies.
13 years 7 months ago #142736 by Jiminimonka
I take it Discuss is what you have called your menu for Kunena forum.
This highlighting is a Joomla issue, not related to Kunena support. Please visit the Joomla.org support forums, and/or the Joomla template provider to see if they can assist with this.
Please read the FAQ.
Only one question per topic.
13 years 7 months ago #142742 by sozzled
This is related to the use of Joomla alias menu types. We've covered this several hundred times in this forum. The answer actually isin the FAQspage. You can also find the necessary information in the Wiki if you search for "Customised menus".
the solution: make your "DISCUSS" menu item an alias menu. The Kunena menu items will then be highlighted correctly.
