Question Disable user control panel
13 years 7 months ago #142304 by TraaBBIT
Hi.
How disable user control panel in Kunea 2.0.4?
In 1.7. ther is INTEGRATOR i Configuration, when we can do it?
hygnhtyjkhtyutuy
13 years 7 months ago #142313 by xillibit
Replied by xillibit on topic Disable user control panel
In Kunena configuration panel, you need to go in plugins to manage integration part.
13 years 7 months ago - 13 years 7 months ago #142330 by TraaBBIT
Replied by TraaBBIT on topic Disable user control panel
And which plugin i should disactivate?
I want to turn off this user panel:
hygnhtyjkhtyutuy
Last edit: 13 years 7 months ago by TraaBBIT.
13 years 7 months ago #142357 by xillibit
You can't just disable it just with a plugin, i had understood something else.
13 years 7 months ago #142358 by sozzled
Replied by sozzled on topic Disable user control panel
I think TraaBBIT would like to know how to disable the login , perhaps? :dry:
