Question How to remove "Mark Topics Read" and "Favorite" buttons?
13 years 8 months ago #142118 by QuakeLive
is it possible and how to remove "Mark Topics Read" and "Favorite" buttons?
Thanks in advance!
13 years 7 months ago #142136 by sozzled
It is possible, if you want to modify the PHP source code, to completely remove these buttons but there's an easier way. You can hide the buttons by adding the following lines to the end of your Joomla site template:
#Kunena .klist-markallcatsread input.kbutton { display: none; } #Kunena .kbuttonuser span.favorite { display: none; }
The following user(s) said Thank You: QuakeLive
13 years 7 months ago #142215 by QuakeLive
The same problem as with changing the color of "Edit" button ( www.kunena.org/forum/K-2-0-Blue-Eagle-Te...f-edit-button#142214 )
I added this code to the end of my Joomla site template (template.css) - but it didn't work. I also tried with custom.css (as explained in that other thread), but didn't work. I'm probably doing something wrong :pinch:
13 years 7 months ago - 13 years 7 months ago #142218 by sozzled
Yes, yiu're probably doing something wrong or your browser is still reading the CSS stored in its cache. Try clearing your browser cache.
You should also remember that the advice we give in this forum is only general advice. There are occasions when people have special circumstances and, in cases like these, we would need to see the Kunena configuration report (as a minimum) or possibly have login access (via a test account) to check things out for ourselves.
Last edit: 13 years 7 months ago by sozzled.
13 years 7 months ago - 13 years 7 months ago #142232 by QuakeLive
sozzled wrote: Yes, yiu're probably doing something wrong or your browser is still reading the CSS stored in its cache. Try clearing your browser cache.
Actually, it works! :) But only for Index page - when I click on (enter) some of categories - then there is "Mark Topics Read" button. If you would help me to remove it, I'd be very grateful! :)
[strike]I have one more question, and I think that I will not bother you more :) - how can I disable option for users to choose which editor they will use. When they go Edit profile, they have an option to choose editor - and I would like to remove that option and only default Kunena editor can be used.[/strike]
Sorry, my English is bad.
Thanks in advance!
Last edit: 13 years 7 months ago by sozzled. Reason: Second question struck out.
13 years 7 months ago - 13 years 7 months ago #142235 by sozzled
I removed your second question. Please start a new topic for it. Someone I the community may be able to answer it quicker if your second question is in a separate topic with a different subject.
I do not have an answer to the main question you have asked, at the moment. I will investigate this for you in the next day or so.
Time to create page: 0.145 seconds
