Question Kunena Latest displays old avatars
13 years 7 months ago #141935 by bigmike0601
coder4life wrote: Do you have your cache set on in the module? Did you try clearing Joomla cache? What happens when you reinstall the module?
The module cache was set to both 'global' and 'never'. Joomla cache was cleared and the module was re-installed. Still yoda appears.
13 years 7 months ago - 13 years 7 months ago #141951 by sozzled
Can we please see you Kunena configuration report?
Can you try a test for us, please? Disable the Kunena - Jomsocial plugin. After you do that, I would like to know if "yoda" then appears on your forum pages?
Last edit: 13 years 7 months ago by sozzled.
13 years 7 months ago #141960 by Mortti
bigmike0601 wrote: The kunena latest module imports old avatar. It will not import updated avatar.
classic-mako.com/
Your url give message now: "Database connection error (2): Could not connect to MySQL."
screencast.com/t/qxtwsd8i
13 years 7 months ago #141964 by bigmike0601
classic-mako.com/
I had DB issues, they are resolved now and link works. Here is the report:
htaccess: Exists | PHP environment: Max execution time: 3600 seconds | Max execution memory: 256M | Max file upload: 20M
Joomla default template details : rt_cerulean | author: RocketTheme, LLC | version: 1.1 | creationdate: February 20, 2013
Third-party components: Jomsocial 2.8.4
Plugins: Search - Kunena Search 2.0.4 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 2.0.4
13 years 7 months ago - 13 years 7 months ago #141966 by rich
Have you uploaded the avatar via Kunena Profile? Or via a other extension? You have your avatars in two different folders.
"images/avatar/" and "media/kunena/avatars/" (the correct path for Kunena Avatars is media/kunena/avatars)
[strike]Please try the following: To rename the folder "avatar" in (images/avatar)"and upload your avatar again.[/strike]
Last edit: 13 years 7 months ago by rich.
13 years 7 months ago #141973 by sozzled
bigmike0601: Can we try the following test, please:
Change the following integration plugin settings:
Kunena - JomSocial Enabled: access=0 login=1 activity=1 avatar=1 profile=1 private=1 activity_points_limit=0 activity_stream_limit=0
Also, update JomSocial - My Kunena Forum Menu, JomSocial - My Kunena Forum Posts and JomSocial - Kunena Groups to v 2.0.4
