Question Using Joomla! article as the topic content. Or better solution?
13 years 8 months ago #141702 by srgg6701
Hi!
I need to place a Joomla! article as a topic on the forum.
i.e. the common idea is to have some General Category like "Rules of our forum" containing a ordinary Joomla! article instead a topic within it.
Also should be a menu item which loads the same article (again as "topic").
I guess (correct me if I'm wrong) there is an option in Joomla! menu manager - I can choose a Kunena menu, then click to create a new menu; point a Menu Item Type as Kunena Forum -> Custom content.
Next I should fill out a Contents field under the Main Settings section (of course I should also choose a menu location and a parent item from the Details section)
Right?
If yes, there are some problems there:
1. Sometimes it can't save a large HTML content. I don't know why, maybe there are some unclosed tags or something else, but the same content displays as an article under a common Joomla! menu without any problems.
2. There is no WYSWYG editor there anyway (I don't need it, but user does).
3. I can't find any way to assign that content as a topic. i.e. I want to load it just as topic from menu and from forum category also.
Is it possible?
Or, maybe there is some more simple way to reach my goal?
I will be very appreciate for any advises!
Time to create page: 0.093 seconds
