Question Category Settings
13 years 8 months ago #141671 by heart0
Category Settings was created by heart0
I have a category set for public/guest viewing and public/guest posting. A "new topic" button appears so that guests can post. However, when I click on the "new topic" button...nothing happens.
Yet, the "new topic" button works great once I login as my user and try to post.
I DO have the security settings set in the Forum Configuration to "YES" for "Allow guests to post/write".
What do you think the issue is?
13 years 8 months ago #141685 by sozzled
Replied by sozzled on topic Category Settings
heart0 wrote: What do you think the issue is?
I do not know for sure. Did you try the Simple forum setup instructions . If this doesn't help, it may be useful to see your Kunena configuration report; the FAQs page (see the menu item above the forum on this page) will show you how to do that. :)
13 years 8 months ago #141728 by heart0
Replied by heart0 on topic Category Settings
Here's the configuration report :)
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 96M | Max file upload: 16M
Joomla default template details : siteground-j16-38 | author: SiteGround | version: 1.0.0 | creationdate: 07 October 2011
Third-party components: CommunityBuilder 1.9 | UddeIM 2.9
Plugins: None
13 years 8 months ago - 13 years 8 months ago #141738 by xillibit
Replied by xillibit on topic Category Settings
Do you have a white page after clicking on new topic ?
Last edit: 13 years 8 months ago by xillibit.
13 years 8 months ago #141754 by sozzled
I would also suggest that you try setting all Kunena integration plugin settings back to their initial default values (see Forum integration with other Joomla extensions for the list of default settings).
13 years 8 months ago #141787 by heart0
No...it just doesn't go anywhere. It just sits there.
