Question Top Menu Alias Item for Kunema Forum Not Active on click
13 years 9 months ago - 13 years 9 months ago #140986 by Snitram
Hey,
I have just installed Joomla version 2.5.9 and also the Kunema forum component version 2.0.4. I haven't installed any other components/modules/plugins.
I created a new top menu item called "Forum Sports" as a "Menu Alias Item" and pointed it to the Kunema Menu's "Forum" item (please see image below).
However, in the site when I click in the "Forum Sports" top menu item, it doesn't get active If I point this menu item to any other menu/article/page, the menu item gets active (please see images below).
How can I make the top menu item "Forum Sports" active when pointing to the Kunema Menu's Forum item?
Thank you.
Last edit: 13 years 9 months ago by Snitram.
13 years 9 months ago #141095 by ernst67
Hello all,
I'm having the same issue on Joomla 2.5.9 and Kunena 2.0.4.
I'm on a Gantry Template (Eris, by Hogash) and I first thought it had somethin to do with either the template or the framework (Gantry).
I've searched everywhere but can't get it solved. Also using an alias to the "Forum" item in Kunena Menu.
Hope somebody can help,
Thanks,
Ernst
13 years 8 months ago - 13 years 8 months ago #141308 by ernst67
I've been searching this forum all evening now, but can't find the answer. I've rebuilt my kunena menu 2 times with no result.
Forgot to include my config settings, so here they are:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : eris | author: RocketTheme, LLC | version: 3.2.19 | creationdate: April 2, 2012
Third-party components: UddeIM 2.9
Plugins: None
Modules: Kunena Latest 2.0.4
Last edit: 13 years 8 months ago by ernst67.
13 years 8 months ago - 13 years 8 months ago #141310 by Snitram
Hey, I was able to get the menu item activated with a jQuery work-around. :)
Insert this code in your template's index file. :)
<script> var isForumActive = <?php if (strpos($_SERVER['REQUEST_URI'], "/index.php/forum") !== false){ echo "true"; } else echo "false";?>; if(isForumActive){ $(".item401").addClass("active"); } </script>
This is not perfect... because you have to "hard-code" the link of your "Forum" page, as well as the class of the "Forum" menu item. So, you'll have to change those values.
Last edit: 13 years 8 months ago by Snitram.
13 years 8 months ago #141324 by ernst67
Thank you Snitram,
I manager to copy the code into the index.php.
But, as I'm not a programmer, I have no idea where to put the link of the forum page and the class of the menu...? :dry:
I'm sorry, just not a techie...
I found out that the link to my forum page is:
index.php?option=com_kunena&view=home&defaultmenu=198
(it's the link that the alias in my main menu points at)
where do I find the class?
13 years 8 months ago - 13 years 8 months ago #141329 by Snitram
Hey,
Do you have all the Kunema's menu itens in the separate "Kunema Menu" that comes by default? If not please try to move all the Kunema's menu itens back to the "Kunema Menu", including the "Forum" menu. After that, I recommend you to create a new "Menu Item Alias" for the Kunema's Forum and assign it to the "Forum" menu item in the "Required Settings" option. In this way, you'll have a more friendly link for the "Forum" menu, something like this: www.yourwebsite.com/index.php/forum
Please see the following image:
If you cannot change this and your link remains the same, then use this "/index.php?option=com_kunena" in the URL of the script.
To see the menu item's class, you'll have to see the HTML source code in your web-browser, because this code is generated by Joomla. So just go to your website, right click the page and select "View page source" and try to find something like:
<li class="item-401"> <a href="index.php/forum">Forum</a> </li>
Or if you have Google Chrome web-browser just right click in the Forum item and select "Inspect element" which will show you where the code line is in the source code. You can also use firebug in firefox as well. The "item-401" is the Forum's menu item class that you need to change in the script. Don't forget the "." before the class name in the script. Something like this: $(".item401").addClass("active");
If this setting doesn't work, maybe you have a jQuery conflict, so try this:
<script> var j = jQuery.noConflict(); var isForumActive = <?php if (strpos($_SERVER['REQUEST_URI'], "/index.php?option=com_kunena") !== false){ echo "true"; } else echo "false";?>; if(isForumActive){ j(".item401").addClass("active"); } </script>
If this doesn't work I can help you using Skype or Teamviewer. :)
Let me know if it worked out.
Time to create page: 0.166 seconds
