Question Kunena 2.0.4 Image in Threads often not shown
13 years 9 months ago - 13 years 9 months ago #140620 by Tom01
Just now I could see the a lot of pictures in threads are not showing. But not all of them. Some are could see from the registered users.
This is really confusing. I did check the path in the thread and the source. the image is on the server an the filename is exactly the same.
Attachements are possible. To see the problem you can use the test-account below.
I'm using a template named KAdonis from 9theme. Its working pretty well - so far.
I read something about this problem in older versions of Kunena. there were changes in the kunena.parser.php the solution. but this file don't exist in 2.0.4. ( www.kunena.org/forum/41-turkish/26012-seviye-yoenetimi#26671 )
Hope u can help!
REPORT:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 200M
Joomla default template details : dreamsquare | author: Fio | version: 1.5.1 | creationdate: 19.10.08
Kunena default template details : NTS KAdonis 2.0 | author: 9ThemeStore | version: 2.0.3 | creationdate: 2012-07-08
Third-party components: UddeIM 2.9
Plugins: None
Last edit: 13 years 9 months ago by Tom01.
13 years 9 months ago #140629 by sozzled
We do not offer support in cases where a third-party template is involved. This condition is stated in the important information printed at the top of this page. You should contact 9themestore and inform them of the problem that you are having.
Where are the missing images hosted? Maybe that's the reason for the apparent and mysterious disappearance of some (but not all) images in your forum?
13 years 9 months ago #140630 by Tom01
The Same problem with the Standard kunena template. So it's Not the fault.
I think this error is since updating kunena to k2.0.4
Before there are showing all Images correctly.
Hoster is all-inkl.
13 years 9 months ago - 13 years 9 months ago #140631 by sozzled
Can you show, here, the actual BBcode used in those messages, please? We need to know mode about the BBcode that was used in those messages and more about the path where those images are stored f those images still exist). It may be possible that you made a change to the image folder or file protections and this may explain why no-one can see them.
When you say "before" (when the images displayed but now they do not), what do you mean? Before what? What version of Kunena were you using before you updated to K 2.0.4?
Can I please see your configuration report that shows you are using the K 2.0 Blue Eagle template, please? We will not investigate further for as long as you continue to use a product that is unsupported by the team. Than you for your co-operation. :)
Last edit: 13 years 9 months ago by sozzled.
13 years 9 months ago - 13 years 9 months ago #140634 by Tom01
Thank you for helping me.
The pictures are don't show with this code:
[img]http://www.goldwaschen-sachsen.de/media/kunena/attachments/legacy/images/granat.jpg[/img]
In the other posts (there the picture is shown) is the follow code used:
[attachment=571]Kopie2von001.JPG[/attachment]
there is also an other target folder (/media/kunena/attachments/xx/) xx=just a number
Maybe before updating from 1.7 to 2.0
13 years 9 months ago #140635 by Tom01
here the new config:
Plugins: None
Time to create page: 0.196 seconds
