Question Problem in IE8
13 years 9 months ago - 13 years 9 months ago #140460 by Maddex
Problem in IE8 was created by Maddex
I have problems with the Kunena Forum in IE8.
It is not possible to place the cursor in the writing area at all, when the Kunena CB plugin is enabled.
If you enable the compatibility view in IE8 (and the Kunena CB plugin is enabled), then the cursor is changed to a "move" and after double clicking a few times it is possible to write. (But it will be too much of a procedure for the visitors, I think..)
Kunena: 2.0.4
Joomla: 2.5.9
CB: 1.9
Plugin; Kunena - Community Builder Integration: 2.0.4
I have realized that it is the plugin that integrates CB with Kunena that is causing the problem.
Any suggestions on how to solve this?
I think I solved it. There is also a plugin "Forum Integration" for CB that seems to take care of the integration between Kunena and CB. So I unpublished the "Kunena - Community Builder Integration" and now it is working in IE8.
Somewhat later:
I did not solve it after all... For what I know now the Kunena CB plugin must be enabled for the integration to work. And this plugin is what is causing the issue.
Please help!
Last edit: 13 years 9 months ago by Maddex.
Time to create page: 0.098 seconds
