Question Emoticons not displaying correctly
13 years 10 months ago #139407 by cnaughton
For some reason my emoticons are showing up as urls instead of images.
Like this edibleartistsnetwork.com/media/kunena/emoticons/smile.png.
How do I fix this so that they show as images?
13 years 10 months ago #139409 by 9themestore
Nice site. Great idea from JA Wall. How can i see this bug on your site?
13 years 10 months ago #139411 by Jiminimonka
Posting your configuration report for Kunena will probably help a lot. Usually this is caused by your template - is the Kunena template you are using updated for the version of Kunena you are using?
Please read the FAQ.
Only one question per topic.
13 years 10 months ago #139412 by cnaughton
I changed the template back to the one that came with the original installation and it still shows the url and not the image.
Any other ideas?
13 years 10 months ago #139413 by 9themestore
I have just registered a account on your site and try to post a topic. So i see it work fine. Can you capture screenshot and post here?
13 years 10 months ago #139426 by sozzled
G'day, cnaughton, and welcome to Kunena.
Perhaps this is what you were referring to:
However, I do not think this is a problem with Kunena or a problem with the Kunena template (which was not developed or supported by the Kunena team) that you are using, either. The following screenshot, taken from your website, shows that emoticon images display quite OK:
I think that the problem is how the user who posted the message (as depicted in the first screenshot I have shown above) has tried to use your forum. This looks more to be an issue of explaining to your users how to insert "smiley" images.
