Kunena 7.0.8 Released
configuration report
Question "Superusers" not shown in Kunena Userlist (Kunena 2.0.3)
13 years 8 months ago #138872
by Schischi
"Superusers" not shown in Kunena Userlist (Kunena 2.0.3) was created by Schischi
Hi all,
i have a little Problem. I just recorgnized that my two Joomla-Superusers are not shown in the Kunena Userlist.
If i check the UddeIM Userlist, the twoe users are shown.
I deleted the superuser-membership of one user and after this the user is displayed in the kunena-userlist.
I hav e checked all the settings but did not find a matching point to this problem.
Is there any option to show superusers in the Kunena Userlist?
Thanks a lot
Ralf
Thanks a lot
Ralf
- 9themestore
- Premium Member
13 years 8 months ago #138875
by 9themestore
Replied by 9themestore on topic "Superusers" not shown in Kunena Userlist (Kunena 2.0.3)
The your theme don't show. You try to use default template of the Kunena. If the default template show supper user, you need check your template.
13 years 8 months ago #138877
by Schischi
Replied by Schischi on topic "Superusers" not shown in Kunena Userlist (Kunena 2.0.3)
thx for reply. I am using the standard "beez5" template, just a bit customized with color and pictures and so on.
May this has got an opther reason why superusers are not shown?
- 9themestore
- Premium Member
13 years 8 months ago #138878
by 9themestore
I think, you should post live url here. If not you can send template for me, i'll help you check it.
13 years 8 months ago - 13 years 8 months ago #138879
by Schischi
Hi, here is the URL:
www.luening-schetschok.de
There is a user/pass for accessing site:
It is viewer / angelsport
If you need the admin login, please let me know...
Last edit: 13 years 8 months ago by Schischi.
- 9themestore
- Premium Member
13 years 8 months ago #138880
by 9themestore
I checked on your site and it's not a bug. The Manager, Administrator, Super User is the same in the Kunena forum.
