Question "Superusers" not shown in Kunena Userlist (Kunena 2.0.3)
13 years 10 months ago #138872 by Schischi
Hi all,
i have a little Problem. I just recorgnized that my two Joomla-Superusers are not shown in the Kunena Userlist.
If i check the UddeIM Userlist, the twoe users are shown.
I deleted the superuser-membership of one user and after this the user is displayed in the kunena-userlist.
I hav e checked all the settings but did not find a matching point to this problem.
Is there any option to show superusers in the Kunena Userlist?
Thanks a lot
Ralf
13 years 10 months ago #138875 by 9themestore
The your theme don't show. You try to use default template of the Kunena. If the default template show supper user, you need check your template.
13 years 10 months ago #138877 by Schischi
thx for reply. I am using the standard "beez5" template, just a bit customized with color and pictures and so on.
May this has got an opther reason why superusers are not shown?
13 years 10 months ago #138878 by 9themestore
I think, you should post live url here. If not you can send template for me, i'll help you check it.
13 years 10 months ago - 13 years 10 months ago #138879 by Schischi
Hi, here is the URL:
www.luening-schetschok.de
There is a user/pass for accessing site:
It is viewer / angelsport
If you need the admin login, please let me know...
Last edit: 13 years 10 months ago by Schischi.
13 years 10 months ago #138880 by 9themestore
I checked on your site and it's not a bug. The Manager, Administrator, Super User is the same in the Kunena forum.
