Question The problem performance - add image
13 years 10 months ago - 13 years 10 months ago #138720 by MarioMari
Hi!
Adding an attachment to post in Kunena, when you are viewing can only see the thumbnail. I do not understand why the browser does not load only the thumbnails only full size image? If the forum contains a lot of pictures that the long wait is too long.
Is it possible to post the thumbnail loading browser drew only a small thumbnail, a full image file will be downloaded only when you click on a thumbnail to view the entire picture?
Regards!
Last edit: 13 years 10 months ago by MarioMari.
13 years 10 months ago #138749 by 810
13 years 10 months ago #138759 by MarioMari
Thank you.
"LazyLoad" - I'm not sure if we write about the same. I have expressed the problem that the images are loaded attachments completely when viewing the content of posts on the site, should be only a small thumbnail files. The whole image file should be loaded only when you click on the thumbnail.
If this is the same problem that I develop is OK and I look forward to a solution.
Regards! and Happy New Year!
