Merged Avatar suddenly changed for all users and unable to change
13 years 4 months ago #138455 by wildplanet
For some reason the avatars for all my users has changed to an icon, and I can no longer find a button to upload an avatar anywhere on the front end of the site. Any advice would helpful thanks
Dave
13 years 4 months ago - 13 years 4 months ago #138460 by sozzled
G'day, Dave, and welcome to Kunena
Wild guess: you've enabled the Gravatar integration plugin. Your configuration report will confirm if this is the case. Solution - if I am correct - is to disable the plugin.
Last edit: 13 years 4 months ago by sozzled.
The following user(s) said Thank You: wildplanet
13 years 4 months ago #138888 by jrousis
Hello!
I made also an upgrade to 2.0.3 and i have one more problem, all avatars disappears and instead of them, i see these images as you see in the attached photo.
Do you have any idea why?
Thanks in advance.
13 years 4 months ago #138890 by jrousis
Just now i show that in the "profile edit" of any user, the "Avatar Image" tag is missing...
13 years 4 months ago #138895 by sozzled
*** Topics merged ***
See my answer in msg #2 above.
The following user(s) said Thank You: jrousis
13 years 4 months ago #139069 by jrousis
Thanks A lot!
Is working!
Time to create page: 0.290 seconds
